Question about Monte Carlo SS nose conversion
itsnotanova
300
16
Bastrop,Tx
I bought a Monte Carlo SS nose conversion the other day from this guy on craigslist for $100. Only problem is that all he had was the polyurethane nose piece and nothing else. I figured I could fab some brackets up or try and find a real Monte Carlo SS, then take what I need from it. The guy I bought it from said you can mount it using third-gen camaro parts, but after closer inspection of a camaro at a junkyard. I don't think it will work. Does anyone have any past experience playing with an el camino with the SS nose??
patmckinneyracing
2,021
36
San Antonio, TX
Are you trying to put a monte carlo ss nose on an el camino??? I was told you couldn't do that because the fenders and doors on the el caminos/ malibus won't match up because the patern on the nose matches the wider pattern on the monte carlos fenders and doors. As far as the brackets, I'm sure you can modify camaro brackets, but I've had some guys have a helluva time trying to use camaro brackets on an ss front end. Different spacing and body lines = big hassle.
itsnotanova
300
16
Bastrop,Tx
This nose is specifically made to bolt on to the front end of el camino's and malibu's. I believe a company called Choo-Choo customs started converting el caminos straight from the factory and then selling them back to dealers back in the 80's. This nose is from one of them. You can still buy the front conversion for like $1200+, but now I believe it's made out of fiberglass. I googled some of those places that still sell them and all I could find was either the whole front conversion or just the polyurethane nose piece.
drknow90rs
117
Wittmann, AZ
I would call choo-choo and see if you can order the brackets from them. Just an idea.... Congrats on a tough find!
Caballero
Oct 12, 2009
58
Does anyone have the link to the El Caminos with different fronts? I know there are some of Pontiac, Oldmobile, and I think even a Camaro
