SScamino said:It's called a 3 speed overdrive and when you put it in D it will go through 3 gears( 1-2) (2-3) (3-4)
everyone else is saying it'll go 1-2 then 2-3 and thats it, after that you shift to OD so now im kinda confused
bill said:On a similar note, I have thought of buying a 88 caprice with a 307 olds and a 2004r trans just for the parts. The column shifter in the caprice has 4 selections, 1,2,D,OD, but my olds has only three on the console. My question is, if I install this trans, I will probably not be able to start out in first and shift it manually, right? Just thinking about all my options...thanks!
The guy wants $350 for the motor and trans and any small items I might want before he scraps it.
redsx2434 said:SScamino said:It's called a 3 speed overdrive and when you put it in D it will go through 3 gears( 1-2) (2-3) (3-4)
SScamino said:why can't you shift to 1st in a 3 speed? its D-2-1??? Maybe it I missed something cause I was skimming.
joeairforce said:[Caprice is most likely has a 700R4 instead of a 2004R.....
