Questions for Quadrajet Users
megaladon6
4,006
15
Danbury, CT
you may be able to use a canadian g-body carb. i think some of them didn't have the CCC carb and they'd need the least mods.
12,186
9,822
Hi Mark,
I'll eventually find something I can use. I've taken these apart before and they don't seem too difficult. I would like to convert it to electric choke as you suggest. So the type that's needed is the one with the hot air choke and not the thermostat/ stove on the intake type.
I also notice that some of the later Q-jets are plugged and don't have mixture screws. But that can be easily rectified.
Mega,
Thanks for your suggestions.
10,599
14,379
Jack, the screws are behind the plugs. They added "tamper-proof" caps so well meaning mechanics wouldn't try to adjust the idle mixture but they just pried those off, so then they put those plugs in the way. To get them off you either have to gently work the stakes out of the way, or beat on them with a punch and BFH. When you see a carb with the base all chewed up around the screws, you know which method was used . :roll: Any help you need with a Q-jet just PM me, I've been playing with them for 35 years.
billyjack
468
56
Western PA
Bonnewagon said:
Try to get a 75' to 81' carb.
I agree. Definitely stay away from the 80's truck carbs. They use a unique primary metering rod which is not compatible with other q-jet series.
Bill
