I plan on removing that, just wanted to make sure i had the right box.Steering arm will not work
That's what I was going by but it didn't really show the boxes all that well and I got confused when I saw the big "Z" stamped on it.^this^![]()
How To Upgrade Your G-Body Steering on the Cheap
A junkyard Jeep steering box and shaft upgrade the early G-body with quicker steering and less slop.www.motortrend.com
You used your old arm from the factory gbody box?I think mine was off a 94 Grand Cherokee, but I just swapped the pitman arms.
Some G bodies had the 600 series box like yours with the round top and some had 800 series(fast or slow ratio). The pitman arms are all different from 600 to 800 and Jeep. 403Olds probably had the slow ratio 800 box to start.You used your old arm from the factory gbody box?
yes, my 85 box had the same output shaft as the jeep. It was pretty much a plug and play, swap the pitman arm, the Gbody hoses fit fine.You used your old arm from the factory gbody box?
