Quick Power Steering Question
tngbody
104
20
oldsmobile joe
2,067
3,053
mpls
Steering gear chart
98 grand Cherokee will work. Has the quick ratio your looking for. But beware, it has more travel than a gbody gear, which may cause tires to rub on full turns.
tngbody
104
20
tngbody
104
20
I think mine was off a 94 Grand Cherokee, but I just swapped the pitman arms.
You used your old arm from the factory gbody box?
carnutjw
622
1,466
Some G bodies had the 600 series box like yours with the round top and some had 800 series(fast or slow ratio). The pitman arms are all different from 600 to 800 and Jeep. 403Olds probably had the slow ratio 800 box to start.
tngbody
104
20
Just an update. I got the Pittman arm from speedway as suggested, cleaned her up, painted and installed. Thanks all for the help.
