Rear Blazer brake swap
hey I'm Mr P nice work I;M having hard time finding the blazer disc brake setup can you fine this setup for me.
Hey Bro,
How about a nice introduction? Tell us what you're working on and a few pics would always be welcome.
Reactions: Injectedcutty
Hey Bro,
sorry about that I'M working on a 1986 Monte SS and I'm trying to put disc brake on the rear i will take some pic tomorrow but if you could help me out it would great good looking out.
Reactions: Longroof79
I have rotors i just can’t find the backing plate anchor brackets for the brakes calipers I need everything but the rotors let me know if you can help me out thank you.
How much clearance is there between the caliper and the frame? I've looked at this on 10 bolt axles with a square flange and could not get the caliper to clear anything without alot of work because of the tall rotor. Can you get a shot of the clearance? What do you have to have to get the parking brake cables to function?
Any idea on the dollars invested?
Thanks in advance.
Looks like a nice set up.
Question: is there provision for the parking brake / cable on the RWD Blazer Brake set up?
How do I make the parking brake/cable work because I might have to put the calipers faceing the front buy putting the left on the right and the right on the left
Thanks in advance.
Yes so far around 200 dollars I know that I will have to cut the axles flange and drill out the holes for the bolts I’m just worried about the e-brakes/cable any input will help thank you.
