Poly binds up the rear suspension since it lacks a secondary axis of movement which is required for 4 link setups. This can cause snap oversteer which is nasty. Most of the aftermarket rear arms are designed mainly for track use and not much street use. If you must have to get aftermarket arms, buy ones with the roto joints. The stock rubber bushing deflect to allow a secondary axis of movement like a crude roto joint. Lubing poly bushings does not stop binding.
The aftermarket, frame mounted rear sway bar is the real improvement. The stock rear sway bars create some binding.
