I hope not … i don’t have a dial indicator. Is there a spec? Maybe i could rig up a primitive oneAny chance the axle hubs are out of true? You could use a dial indicator to check.
Well the rear end is a fresh rebuild and spun freely without brakes on it. It is definitely brake drag. As far as brake lines, i just finished buttoning that up, bled and everything....The rotors actually are not bolted down at the moment but i had em bolted when doing the install, I'll have to go back and try this again. Was waiting to finish up my wheels...I do have the slightly longer barrel spacers sitting on my bench which i guess might be worth a try (simplest thing to try first) i just dont understand how spacing them out more would help, both pads are already touching.Yes you need to shim calipers to center them. A bit off center will not cause drag but if it's way over, it may be bottomed out causing you drag.
If it's all new. I would disconnect things to narrow down the problem. Undo brake line to confirm it's not hydraulic, remove pads to confirms it is the brake or not.
Do you have the rotors bolted down?
Yes I installed the shim between the housing and outer flange bracket (2:40 or so)Inline installation video:
16:00
When you say shim the bracket from the housing are you referring to the backing plate delete shims?
Ok thanks for the helpI watched the video, that first plate is what I was referring to. Mine just had washers(cheap). I'd do what RT said to narrow it down.
Alright Im a dummy, lol. I am working on another house project ATM but i popped in the garage real quick and tightened the lugnuts down... better i think but still prob. Too much drag. Looking over the top of the rotor, there is a big (3/4" or 1"bolt cant remember) that goes thru the mount and the housing plate. The head of this bolt is basically up against the back of the rotor although i dont see any scratches or wear marks. Guess i gotta burn this head down a little bit first and then see where Im at ....Yes you need to shim calipers to center them. A bit off center will not cause drag but if it's way over, it may be bottomed out causing you drag.
The spacer between the housing and the mounting plate should have increased the distance from the head of the bolt. Grind the head down a little bit at a time until there is more clearance to the rotor. It's worth a try.Alright Im a dummy, lol. I am working on another house project ATM but i popped in the garage real quick and tightened the lugnuts down... better i think but still prob. Too much drag. Looking over the top of the rotor, there is a big (3/4" or 1"bolt cant remember) that goes thru the mount and the housing plate. The head of this bolt is basically up against the back of the rotor although i dont see any scratches or wear marks. Guess i gotta burn this head down a little bit first and then see where Im at ....
Ok guys, this question is for everyone…Yes you need to shim calipers to center them. A bit off center will not cause drag but if it's way over, it may be bottomed out causing you drag.
