So basically put a brake bias valve in or go bigger with front brakes
Not necessarily, also have to factor in area of the pad engagement into the equation.D154 in and of itself could mean more than 1 thing. For example:
Wilwood Disc Brakes - D154 Front Caliper Kit
Wilwood bolt-on front brake conversion kits are designed to provide superior braking performance and a highly detailed appearance over a wide range of domestic and import applications. D154 Front Caliper Kitwww.wilwood.com
If the stock caliper piston was 2.5" then a stock piston has an area of 4.9 sq/in. OP replaced that with calipers with an area of 4.12 sq/in and thus downgraded.
