Just finished up my rear drum brake upgrade, since there aren't too many pics of the process i figured i'd share mine.
first replaced stock 3/4" bore wheel cylinders with S-10 7/8" bore. I also highly recommend using wheel cylinder bracket because the retainer is a pain in the *ss to get in and sometimes they are still loose. I couldn't get the new retainer in so i reused the old ones just to hold the wheel cylinders in place to install the brackets. You will need a 15/64" drill bit to install the brackets.
You then want to use two primary shoes per side, the one on the bottom is the shorter stock secondary shoe, it has about 1/2" less contact area then the primary.
And that is basically it, you gain more holding power which is good for launching and i would say more stopping power although this is highly debated lol you can also replace the rubber lines with stainless steel braided ones for better response, but I seem to have bad luck with brake lines so I didn't..
I also replaced the stock cast iron drums with aluminum drums to save weight and better heat dissipation + i love the look of aluminum.....especially when polished 8)
have cat litter all over my garage so everything is a little dusty
