JBreu said:That 7.5 came out great and for your purposes, it'll do the job. I just wouldn't throw 500+ HP
at her...Now that 8.5, hats off to you bro, looks awesome!!! Good, no wait Great job!!
Aw man I really appreciate the comment 8) ! Thanks for the heads up on the 7.5. The 7.5 is goin in my 78 malibu with a lil 350 with maybe just over 300hp. Nothing crazy. I'll be running stock 15" Monte Carlo SS wheels and a 235/60/15 tire for daily driving. An occasional donut or lil burn out. But mainly daily drive to work and Arizona. Preciate' the feedback and heads up 😀
THANKS FELLAS!! 😀 Really appreciate the feedback. I worked on this one and my Grand national rear at the same time-going back and forth on both rears. Knocked both out in no time at all. The 8.5 Came out Killer and was a lil more involved because I had to do the entire swap from drums to disc. Really easy to do (with the correct tools) Here's a few pics of the "Grand Nasty rear after I did the swap and did the same cleanup...I added the photos here to show all the "new dudes" like me that we can do it too!! Lil time and patience, and work safely and it can be done...
Grand Nasty 8.5
Aircraft stripped the POR-15 off. It was lifting in areas so I decided to redo it..
TA Performance girdle Stripped and I sand blasted it Clean..
Grand Nat's axle tubes. I cleaned and sand blasted em at work and pressed out the old studs and pressed in some ARP studs
Wire brushed the rear
LOOKING CLEAN!!!
Getting ready to cut the rear flange and decided to clean this up
Added the ARP main cap kit...
Pressed out the old bushings
Decided to spray it right quick to keep the surface rust at bay. I'll start a project and then let it sit for a while (get lazy basically lol) so I added a lil Eastwood primer..
Cut the flanges...
Mock up with the cleaned up backing plates...
With the studs pressed in and rear caliper mocked up...
Fin...
Same Kore3 braided lines were added as well as the SpeedBleeder setup. Came out clean for a "homegrown/backyard boogie" job.Thanks again for the cool feedback. Really gets me motivated to work 😀
Elco Warren 8)
80z
