Rear hatch weatherstrip( Update)
nawlins-tim
nawlins-tim
246
New Orleans, LA USA
A week or two ago I made a post about the fact that how we can not get the weatherstrip for the rear hatch of our wagons. Well I heard from this forum that a 90's Caravan weatherstrip will do the trick. Well I fit the pichweld fine. I even made a post , Here , about it. I was all happy until It rained. Yep NO GO!!!!
After further Investigation the Caravan weatherstrip DID NOT SEAL in about 80% of the enclosure. Well that was removed and I sourced a universal piece that I am POSITIVE fit and sealed. I got the item from STEELrubber.com I ordered 17 feet at about 6.50$ per foot. I had some close to 2 feet left overs. I'm going to add the part number in a minute. But This is definitely something to look into if you can round up 125 dollars to repair your back hatch seal, because I bet 90 percent of the wagons out there is in need of some attention in that area. And if its let go too long, You will have rust hole in rear glass surround like I did.
They called it a "push on universal" weatherstrip. Part number 70-2831-99 once again at Steelrubber.com good luck
nawlins-tim
nawlins-tim
246
New Orleans, LA USA
You know.. I was so embarrassed that I failed the first time. And wasted the 40 bucks on the caravan product. That I deleted that post. Although I may have worked for others... It just wouldn't crush enough to seal. But this piece is much taller . So I hope this helps.
Longroof79
Longroof79
Rocket Powered Basset Hound
Oct 14, 2008
10,074
Gainesville, Fl
Sorry the Caravan seal didn't do the trick for you. However, thanks for posting the information about the type of seal you finally ended up using in that area.
I'm actually back to using an OEM seal that I've had stored away for years. I never tried it out in the rain yet, but I'm sure it could be upgraded.
I'm guessing a proper length of G-body trunk seal would work well.
CaliWagon83
CaliWagon83
1,850
Orange County, CA
Don’t beat yourself up. There’s a lot of trial and error with these cars, especially when it’s hard to find replacement parts, and you have to improvise.
HooptieWagon
HooptieWagon
6
Maryland
I put a used first gen S10 Blazer rear seal on my wagon. Works some of the time. Or the car leaks from the roof rack, not sure. Maybe a new S10 Blazer seal will work, if they are available anymore.
Longroof79
Longroof79
Oct 14, 2008
10,074
Gainesville, Fl
jwobbles07
jwobbles07
22
13
Los Alamos, NM
Let us know how well it works out.
Sat outside for a month due to me moving. Got a about 2 feet of snow in 2 days. Didn't clean off the car and let it all melt. No leaks, but I'll wash it here soon and hit it hard with the hose to make sure.
Reactions: Longroof79
SSpev
SSpev
109
I hope the van seal doesn't leak. mine sets out side all the time:unsure::oops:
Thread starter Similar threads Forum Replies Date
J Wagons! 2
finkous Wagons! 8
nawlins-tim Wagons! 2
nawlins-tim Wagons! 5
8 Wagons! 3
