Those bolts look like an unanticipated right or left turn on launch waiting to happen depending on what side breaks. ...
There's nothing special about the 'spacer' you can't reproduce if they are rusty. You just need some steel pipe with an ID big enough for the bolt to pass through, and, an OD small enough that the flanged surface of the bolt heads and nuts extend wider than the pipe.Thanks everyone for the good info. Looks like it will be a pretty easy job since I won’t necessarily need to change the arms. I’ll just swap the parts over. Hopefully when I pull the bar off the Monte arms, those inner support spacers will be good enough for continued use. If they are, I’ll treat them to POR15 before putting them in.
By the way, the front has already been treated with a GN sway bar and Bilstein shocks
I'd probably change the bolts because they're cheap and at least one has visibly narrowed in thickness, but, the spacers look like they'll clean up goodI have not cleaned them up yet but all the parts look reusable.
View attachment 219377 View attachment 219378
I’ll make a final judgment on the bolts after wire wheelin’ ‘em. If they have only slight wear I’m the type that would use them. But not until after slathering them up with anti seize compound. That will prevent any further degradation.I'd probably change the bolts because they're cheap and at least one has visibly narrowed in thickness, but, the spacers look like they'll clean up good
I think you're giving too much credit, at least for the reason you speculate.It’s interesting though if you think about it. Why didn’t the factory just use sleeves instead of the insert piece like they did? I think the insert also plays a role to stiffen up the control arm along the area that the bar is secured against.
Note that in the earlier A body cars, the cars that came factory with rear stabilizer had gussets welded across the control arms in that area. So I think the inserts in the G body cars are designed to perform the same basic function of the welded gussets on the A body cars.
