I just realized my Regal's rear end is offset toward the passenger side by 1/2 inch. So I checked my El Camino, its rear end is offset toward the passenger side by 1/2 inch also. What's the deal?
megaladon6 said:or it's just the usual GM lack of attention to detail.
pontiacgp said:... I'm not sure about the engine and tanny being off center. When you put a metric on the scales to set it up got the track the right side weight doesn't start off any heavier than the left side
LS1GN said:pontiacgp said:... I'm not sure about the engine and tanny being off center. When you put a metric on the scales to set it up got the track the right side weight doesn't start off any heavier than the left side
All four corners have different weights.
