rear spoiler
roachownsu
112
2
is a monte carlo ss rear spoiler compatable with putting it on a 85 cutlass supreme?
FE3X CLONE
2,714
51
48
Ohio
Yes, with a little modification. You need to either trim the tips so they clear the top of the taillights or cut them off completely.
roachownsu
112
2
hey thanx FE3X.. yea im going to to put the monte carlo spoiler on it instead of the 442 spoiler.. it just looks cleaner.. btw i like the adjustable spoiler you custom made for your cutlass.. wish i could get one of those..lol
FE3X CLONE
2,714
51
48
Ohio
I actually have the later model SS spoiler on my Cutlass.
Angelo Valenti, who owns one of the FE3X cars is the one that had the rear spoiler made that mimics the original concept car spoiler.
FE3X CLONE
2,714
51
48
Ohio
roachownsu said:
whats the difference between the monte carlo ss spoilers? pics would help
The earlier models stand up more where as the later model is closer to being flat. I don't know what years they switched between the two.
I believe this is the more vertical spoiler:
This is the later model spoiler. It's more flat:
Young0utlaw81Cutlass
158
21
Dallas Tx.
It sure looks nice SS spoiler on a Cutlass i decided to go this way on mine but i would like to know how much do i have to cut off and size of drill bit to make holes on my trunk
FE3X CLONE
2,714
51
48
Ohio
Young0utlaw81Cutlass said:
It sure looks nice SS spoiler on a Cutlass i decided to go way on mine but i would like to know how much do i have to cut off and size of drill bit to make holes on my trunk
How much you need to trim depends on the car and if the spoiler hits your taillights. If you don't want the wing tips to extend over the taillights you can cut them off without too much work since they are hollow underneath.
As for the trunk holes, the studs on the spoiler are around 8mm in diameter so you'll need a drill bit a little larger than that. I made the holes fairly large so that it would give some wiggle room adjusting the spoiler side to side.
BigGeorge
29
FE3X, I see I am not the only one that likes that look. Do you have any actual pictures of the rear of your car that you can post? Do your tips extend over the tail lights? Cutlass' should have came with this type of spoiler from the factory as an option. Something is needed on the back to give it a little more "bam".
FE3X CLONE
2,714
51
48
Ohio
This was the spoiler on mine before bodywork and paint:
This is after we cut the ends off and put a few coats of primer on it:
Should have a few pics in a few weeks of everything painted and installed for final comparison.
