307 Regal said:If I remember correctly, having a stiffer bar in the rear than in the front will cause understeer, and vice versa.pontiacgp said:the rear bar should never have the same or greater spring rate than the front...it upsets the traction coming out of the corner. It takes alot of tweaking to get the car to work rotating corners with a rear sway bar.
With a bar that hefty looking in the rear, I would look into getting a front sway bar upgrade if you don't already have one.
I was running s-10 springs and 36mm gta sway bar, so giving the car this sway bar definately put each end on the same level
