The Oldsmobile as an original SBC car and yes it still is. The current motor is a 421 inch and makes about 660 horse. Run`s 10.30`s at 2700 feet. The car I am looking for a bigger sway bar for is an 83 Malibu wagon that my daughter runs in sportsman at PIR in Portland Oregon. The Malibu has a 1" bar now and needs more. Just looking for OEM before we go aftermarket.3/4, I believe. Now, where is your build thread or let's see some deets on that Salon roasting the hides! (fingers crossed it's not a Chevy)
Thanks for this infoThe only "factory" upgrade over the stock bar would be the 1" 98-05 4wd 2dr blazer bar that mounts to the frame instead of the LCA. Very similar to what you get in the $180 helwig bar but can be picked up at a salvage yard for ~$20 I've got it on my LS2 t56 GP that runs mid 11's and it has worked great so far.
3rd gen F bodies also had a bigger bar that mounts similar to the blazer bar but the arms that go to the end links flare out and they have to be heated and bent inwards.
