Rear window shelf removal
Martin S.
137
198
Hamburg, Germany
Good afternoon community,
the rear window shelf from my car (78 chevy Malibu, 4door) looks really bad; its scratched. Now I want to remove it, to rework the part. Does anyone know how to remove this f......... part ? :(:blam:
I would be glad for any tips or suggestions (with pics ?)
Many thanks in advance
Martin
85ss/85gn
286
254
beaver dam,wi
The interior trim piece? Not the metal? There is some screws on the side trim that need to be removed. The top part of the seat needs to be removed.
  • Useful
Martin S.
137
198
Hamburg, Germany
Yes, the interior trim........... and how do i remove the upper part of the rear bench ?
I had a look in the manual, but i didn´t found anything.............:(
pontiacgp
blank
Mar 31, 2006
29,270
20,391
Kitchener, Ontario
to remove the upper part of the rear bench you remove the seat and there are two torx bolts you need to remove. The bolts are also used for the seat belts. I find to help get the bolts out I place the torx bit (I think it's a 54) in the bolt and with an old 3/8" extension attached to the bit I give it a few good hits with my mini sledge hammer.
  • Useful
85ss/85gn
286
254
beaver dam,wi
It is a t50 torx. The lower seat is clipped in just need to push the front side in and should pop up and the upper you will see the torx bolts
  • Useful
85ss/85gn
286
254
beaver dam,wi
If you have more questions I just pulled interior from a 4 door and still have most stuff in my head
  • Useful
ed1948
1,286
1,613
Quinte West, Ontario
I might help to spray penetrating oil on the exposed threads under the chassis. Those bolts can be a b***&#$&*!!. to loosen. While you're under the chassis please hit any other exposed threads with penetrating oil.
  • Useful
85grandprix
251
391
I stripped two..so now i have to figure out how to get them out..they really are a pain in the a**
