Recommendations for a carb/mani
Reactions: Longroof79
I was thinking the 350 cfm would be better for throttle response
I have always found that the CFM calculators like to stay on the conservative side since they don't require anything other that the most basic information.
the size of combustion chamber does not change with a cam or headers or an intake, bored over engines increase the combustion chamber but marginally so there is no need for a higher cfm carb unless your running the engine at high rpms. When we ran in the Luca Oil Sportmans series we ran a built engine that could run at 8000 rpms the whole day, we switched cars so we ran a 604 crate. The carb we were limited to in that series was a holley race version 500 cfm
Do you know anything about the cam, compression ratio, what's been done to the heads? if not, on the safe side get a 500cfm two barrel. that's about as large as you'd want to go. Or of course, you could always go with a q jet.... impossible to over carb with a q jet.
I would get a 500cfm edelbrock. And tune it . If you have a 4bbl intake headers dual exhaust and cam. I am sure it will like a 4bbl.
