Fti converters is what I used. I gave the my cam specs, rear ratio and I think tire diameter and they gave me a recommendation. I'm using a 2800 stall in mine.
If you are confident in your tuner's abilities then there is no reason not to go bigger with your TC selection.
If you haven't seen it already... here is something to chew on: https://ls1tech.com/forums/automati...e-converter-stall-torque-ratio-str-guide.html
FTI offers a pretty wide selection through Summit: https://www.summitracing.com/int/search?PageSize=100&SortBy=BestKeywordMatch&SortOrder=Ascending&keyword=fti 4l60e&N=4294949305
I thought it was alot simpler than that. lol. I still havent been able to finish reading that whole thing. I guess I should figure out if the converter guy can just build it according to my set up.
my dumb question of the day.....with a stall speed over the rpm of the cruise speed of 60 mph if you drove the car at 60 mph would the TC be slipping as you drove causing it to heat up?
goggle said:A torque converter consists of three parts: a pump (impeller), a turbine (runner) and the stator in between. As the torque converter rotates, the pump spins and the centrifugal force generated causes the fluid inside the torque converter to be forced outwards and onto the blades of the turbine, making it spin in turn.
Maybe.
We are talking about a hydraulic coupling here so that is going to be influenced by a series of factors:
Buy a budget converter and prepare yourself for budget problems. A huge contributing factor that is often overlooked is the fluid used. I actually used high-viscosity hydraulic fluid in my Buick to tighten it up. If you run Dex 6 you may find yourself on the wrong side of slippage at speed.
Ironically my cruise rpm at 60-70mph in the Buick was very close to the advertised stall speed. So... it is better to speed then it is to let your trans overheat.
I'll try to out-dumb pontiacgp with my question. How does "lock up" affect his question of TC slippage at cruise when stall RPM exceeds cruise RPM? I was hoping lock up would make that problem go away entirely.
Is that dumb enough?
Cheers - Gary
