I'm going to be swaping my engine, and i wanted to clean up and paint my(firewall,frame,core support, etc) while the engine is out. Does anyone have tips,suggestions as to what paint, and good way to clean/ and degrease my engine bay?
80' bu said:I sprayed mine down with gunk degreaser then pressure washed the engine bay. Wire wheel in an angle grinder or drill to get the flakes and crap off. Finish it off by washing it with soap to get any residue off and POR it. POR is expensive but I was amazed at how nice that stuff is and it'll lay flat even when applied with a brush. I used the POR metal prep before paint too which helps adhesion especially when you've de-rusted it. POR actually likes rust to stick to.
v8power said:go to walmart and get super clean in the purple bottle, do not mix it with water and spray it on and let it sit for 10 min, then use a pressure washer to blast all the crap away, you will be surprised how well the super clean works!!
then as far as the frame, i just used dupli color professional under coating, and put about 3 coats of it on, or until it starts to lay smooth. get a good primer and prime and paint the fire wall. i just used spray paint, but it looks really good. as far as the fender wells, i am just going to paint them bumper black. good luck.
http://gbodyforum.com/photos/displayima ... 259-2.html
v8power said:thanks, i did it all myself. i would say it took about a week to do all the cleaning and paint. the biggest thing is that super clean degreaser, it is by far the strongest stuff i can find. i took all the wheels off and rolled it outside on a jack, and made sure to get all the grease out by the spindles and a arms. that dupli color professional undercoat works really well, just have to put it on in layers so it will look level, otherwise it is really rough. the fire wall is just D.A. sanded down with 180 grit, to get all the factory runs and puddy off. then do 2 coats of primer, and 2 coats of paint. i will post some pics up of the fender wells when i get them painted.
by the way, are you going to do all the bushings rite away?
