removing ac
So the water pump and alternator use one belt .and the power steering and the A/C use another belt. Im thinking the should be a belt from the crank pulley to the power steering pump. If there is a belt from the crank pulley to the power steering pump you can remove the belt for the A/C . On a motor with out A/C there is two belts. One for the water pump and alternator ane one belt for the power steering.
Doug
k one belt goes from crank to alternator and water pump
other belt goes from either the water pump or crank to ac and power steering
Ok, looks like there is one belt the run on the crank, water pump and the alternator. The other belt run on the crank, water pump, A/C and the power steering pump. So remove the belt that runs the A/C and get a belt for the power steering for your car.
yes but how do I tension that power steering? is there adjustment on the power steering pump?
