My daily driver Malibu had a broken body mount bolt on the right side at the firewall. Body flexing resulted in a cracked windshield at both upper corners. Of course all the mounts should be replaced on a 39 year old A body that has over 237k miles on it, but that job will occur once it is possible to lay the car up for more than a weekend. Just wanted to repair the immediate body mount problem, so I can then get a new windshield installed. Fortunately the firewall mounts are the easiest to get at as there is a "window" build into the mount's housing. This window allow removal of the cage nut.
How it is possible to remove the cage nut is to heat the broken stud from the frame side while grabbing on the stud with a pair on needle nose vise grips that is accessible though the "window". Using my old oxy/acy welding torch setup, once things get hot enough, it was possible to free the cage nut from the mount housing. Then it is just a matter of removing the stud from the cage nut. The original upper mount between the frame and body will be retained for now, but removed prior to heating up the mount housing. One other thing, the body mount will not come out until the body is raised a little. I used a really big screw, (it's really big), wedge between the frame and body and that leverage was enough to raise for the needed clearance, but a floor jack place under the body along with sufficent wood to spread the load would work just as well.
