84Hurst/Olds said:Start with the middle bolts, and work your way out.
This is incorrect. You start at the corners and work your way into the middle.
DoubleV said:84Hurst/Olds said:Start with the middle bolts, and work your way out.
455rocket said:DoubleV said:84Hurst/Olds said:Start with the middle bolts, and work your way out.
Been a long time since I did one of these,wudda never thunk it. Most go middle out.
lillee64 said:outside in is a horrible way to go, ive seen cracked intakes because of it and if u think about it, it makes no sence, why get the outside tight before the middle? when the two meet there, the middle of the intake is now understress.work your way out from the inside and it all lays down smooth. i think maybe they changed that picture over the years because i no longer see any stating to go outside in. even with the lsx motors, its inside out
84Hurst/Olds said:Well at least you will have an all new cooling system now.
