Spent a couple weeks getting the boat ready for the year ( ended up with a headswap on the AQ131 2.3 Volvo ). Now back to the Monte
Last night I got it all torn down.
With the intake, pushrods and lifters pulled I could see the adjustment was still pretty good ( prying the cam back and forth thru one of the lifter bores ) but I did see some flexing / movement in the cover ( this is with the nylon cam bushing ). When I pulled the cover and this is what it looked like ( the black & silver circle is where the nylon button was rubbing into the cam cover and chewed up the paint ). This is a heavy aftermarket timing cover BTW
Shot of the backside of the replacement cover ( its a Jegs unit same as the milodan mentioned above ). I have also switched to a thrust bearing ( you can see it installed in the engine pic above ). I spent about 20 mins going back and forth denting the cover to get the correct clearance ( it was appx 1/8" too shallow ). Kinda wishing now I would have spent the extra on the cover with the set screw ?!?!
I took about 3 hrs last night to tear it down, clean the gaskets surfaces, clearance the new cover, and put it back together again ( man are my back and calves sore from hanging over the fender !!!! ). As I left for work this morning I lined up the oil pump, put the distributor back in, and the wires back on. It sputtered but it wouldn't start. Maybe tonight if I can get to it before it rains I can get it running, set the timing and top off the fluids.
Supposed to rain for the next couple days ( no garage ) and it would be nice to take my wife to brunch in the old car for mothers day. Somehow I think we will be taking her car instead 🙂
