Rpm on tach goes down when rev engine? Why?
20,397
what brand of tach do you have did you recently install the it?. Have you checked the wiring?
Wageslave
1,750
3,342
I would suspect electrical noise on your tach wire. Is the tach wire from the distributor close to any of the plug wires?
hunter_alexander
303
161
Erie Pa
Didn't do anything to the car yet. All original. It was working fine. Then it just started dropping to zero when I revved the engine.
Wageslave
1,750
3,342
It could be as simple as the plug into the distributor is loose. Try unplugging and cleaning the connection into the distributor and see if that helps.
hunter_alexander
303
161
Erie Pa
Ok, not the dist wire. The tach sits at 1k until u rev the engine then drops to zero.
hunter_alexander
303
161
Erie Pa
Just an update... So unhooked the tach wire on dist and ran it. For a bit the tach was still doing it so def something with the gauge cluster. Guess a rebuild is in order.
I seem to remember somewhere on the web someone hard wired the gauges to bypass the flimsy plastic circuit board on a cutlass before. Anyone know what I'm talking about?
