Cutting out the T-bar w/out extra rigidity added to the A pillar assembly is a serious issue because the A pillar will fold back if struck at all.
As for the rigidity of a FACTORY Ttop car they have extra bracing that a solid roof car does not. The factory Ttop cars have a structural bar built into the Bpillar and roof that adds a Structural hoop that the Tbar ties into to hold the A pillar forward. The other part is that on all modern cars (ours included) the windshields are glued it because they are designed as a structural part of the A pillar section which allows even loading of forces. As for twist in solid roof vs T roof models that is a lack of improvements by the owner/buider because in order to severly twist the frame you have to increase HP/Torque output to above vehicle engineers design. Like any modification every part has an effect on another and the car has to be built as a complete package not a collection of assorted changes. As to why turning a G-body into a targa top is less feasible as a simple size / weight issue. Think about lifting both sections of the Ttops out at once from one side of the car. Nearly an impossible task for most people.
