Thanks between Christmas and my son getting sick I haven't had much time to work on it. Im hoping to get some good time in this week.Love your hustle and the progress you are making!
Thanks for the tip. Im thinking I'll need to fix 3 like that, all in the trunk.I made my own cage nuts using 1/4" thick 2" X 2" Unistrut flat plates I get from work (electrical supply) and weld a nut on top.
This ☝was awesome advice. It made it a breeze. I can't imagine how much harder it would have been without it. The HFT spot weld cutters walked on me alot so i started drilling 1/8 in pilot holes. It helped but I kept breaking them , but they let me return them. After the floor was out I went through with seam splitters,spot weld cutters, 5/16 bits and 2 grinders with cutoff/grinding wheels each. I used the spot cutters for anything I wanted to save and the grinders/drill bits for everything else.This was time consuming but not extremely difficult.Spot weld cutters work great. Use a punch in the center of the weld first, so the cutter doesn’t wander on you. You’ll learn the feel of the tool when you go through the first layer of metal, you DONT want to go through both. I’d suggest cutting the bulk of the floor out first within about an inch or so of the factory welds. With the floor gone you can work on the welds from inside the car, having room instead of becoming a contortionist. Just don’t be a Tim Tayior (Tool Time) keep checking under the floor before and as you cut so you don’t cut anything you don’t want to. Cutting out and trimming neatly will save alot of extra work when you install the replacement floor.
Thanks for all your help and encouragement!! Seriously every piece of advice has been a blessing. Especially cutting the floor to the factory seams. Any advice on overhead welding. I damn near caught what little hair I have left on fire lol. The work you did on the elco wagon is unreal. Its Gotta be the only elco wagon out there.Glad to see your progressing/learning . Body reconstruction isn’t painless. You’ll make some mistakes, as long as you find them and fix them you’ll be fine. More sheetmetal and welding will fix most anything you run into. It takes alot of patients and work to transfer the small but important parts as you’ve learned. It’s tough even when your experienced .to stay focused and patient enough to continue correctly . Look at what you’ve already accomplished and remember your goal and proceed. Real good job so far, especially for someone new to type of project. KEEP GOING !!!
Im not very far into your SS build but im pretty much hooked so only 60 more pages or so to go. You should rename it the 4. GREAT. With Twins their awesome. Ill be honest I feel like Im barely brave enough to do the bare minimum bodywork. The artistic licensing might have to wait for the mechanical part of the build. Which I promised myself I wouldn't even think about til the body/frame are straight...But since I bought an 05 silverado 2500 2wd with 47k miles and is made up of 50% rust its getting harder....This feels all too familiar. Stick with it and feel free to use a little artistic license. 😉
Thanks for the tips. I already used the copper trick and works like a charm. I wrapped some copper gutter around a dolly to fill in the firewall holes. I bought a welder with a bunch of accessories a while back. 2 were copper bars 4x3in and 8x3in with magnets embedded. Now I know what there for. I looked up the mule skinner 80 bucks for a wire wheel makes me apprehensive but I trust you and any product that hasn't changed in 40 yrs. I also like the idea of it not flying apart especially with my son helping more. So I'm ordering it next week. I started out buying the cheapest consumables possible but they burn up so fast and do a mediocre job while there good. The only cheap consumables im using now are the HF spot weld cutters(they let me return broken ones). Even the HF solid wire is trash. I went and bought more lincoln superarc. So it seems atleast to me cheaper isn't always better.Im fitting the driver mount this weekend. It should go alot smoother since the kick panel is good. I also got a heat gun for the seam sealer and helps quite a bit.Got a few tips for you, 1 for any small holes you have in your metal ( like when the little hole saw went through both layers ) flatten out a piece of half inch copper pipe to use as backing when you weld/fill the hole. The weld won’t stick to the copper.This also leads to step 2 good sized magnets can be VERY useful for this and other tasks. I got a bunch years ago, can’t tell you how many times they really helped. 3 is a very good tool, it’s called a Mule Skinner wire wheel . It’s sold as 2 pieces, the arbor and the wheel. The wires on the wheel are packed in an epoxy so they don’t come out and fly around like regular wire wheels. The idea for the 2 pieces is that when it starts forming in one direction, you take it apart and flip the wheel over. They DON’T work in reverse, it will come unthreaded if you do. Since the early 70s I’ve only ever bought 2 ( I lost the first one ) they are WELL worth the price for cleaning around welds and any small areas.View attachment 133668
