Stealing this thread from a Z28 forum for the most part, with a few modifications for the purpose of providing a comprehensive parts list for a Blazer-S10 rear disc brake conversion. Second Gen F-Body enthusiasts do a similar conversion to what we do, except they use the 4WD set up for the passenger side, and the 2WD set up for the driver side in order to give them a staggered brake set up since that's how their suspension is in the back. Since we can't do this due to frame clearance issues, we have to use both sides off of a 2WD set up if we also want to guarantee clearance for 15" rims, which is the reason many of them do this as well.
Original thread and credit for (most) of this goes to Woody80Z28
http://nastyz28.com/forum/threads/s10-blazer-rear-disc-conversion.109454/
This is good for people who want rear disc brakes but can't do the LS1 conversion because they like the 15" rims that they have and aren't sure that the LS1 brakes will fit inside of them.
If something like this already exists, please disregard this thread. I didn't see it in the search.
Parts you will need:
Outside diameter: 11.61"
Height: 2.87"
Thickness: .79"
Mounting face to friction surface: 2.08"
E-brake surface diameter: 7.5"
Caliper Specs
Aluminum
Single 1.875" piston
Floating
http://www.motortopia.com/album/view/p/cars/t/vehicle/v/182/a/8370/i/big_brakes_frontrear_disc
http://www.nastyz28.com/forum/showthread.php?t=94303
- 1 - Driver side 2WD backing plate (GM PN-15773308 whole e-brake assembly) (GM PN-12376603 for just the backing plate)
- 1 - Passenger side 2WD backing plate (GM PN-15773309 whole e-brake assembly) (GM PN-12376604 for just the backing plate)
- 8 - 3/8 bolts, lock washers and nuts to mount backing plate to rear housing
- 3/8 washers to shim the backing plate for perfect fitment of the caliper to rotor (2 each bolt in my case)
- 2 - Driver side and passenger side 2WD caliper, mix & match (Loaded kit w/ brackets & pads Cardone PN-164712) (Loaded kit w/ brackets & pads NAPA PN-TS 1422228)
- 2 - Caliper brackets - if needed
- 1 - Brake pad set - if needed (HWK-HB305Y-610)
- 4 - caliper bracket bolts (GM PN-15726460)
- 2 - banjo bolts (GM PN-10286122)
- 2 - 2WD Blazer rotors (NAPA 4886725) (Powerslot 8638PSL & 8638PSR)
- 1 - Master cylinder (80 disc/disc T/A, 79 disc/disc Vette, 70 manual disc/disc Vette all work)
- 2 - Brake hoses (you can use stock Blazer hoses or any braided stainless ones with a 10mm banjo fitting)
- 1 - Prop valve (stock 80 T/A works, I used a Summit adjustable)
- New style brake cable (I used the Blazer cables, but Lokar universal would be less work)
- Brake fluid, gear oil, axle seals
Height: 2.87"
Thickness: .79"
Caliper Specs
Aluminum
Floating
