Saving a dead battery?
Turbolq4
1,732
4,207
Nampa Idaho
Hook jumper cables to a good battery and the bad battery. Apply a 5 amp charger to the good battery at the same time. If that doesn't work then it's junk.
19,994
Pep Boys will give you a 20 dollar gift card for it.
20,413
It sucks ruining a battery and if you can't get it recharged and feel confident with it is not worth worrying about getting suck someplace....plus a weak battery puts extra strain on the alternator
19,994
10,581
14,326
I was told never to zap a dead battery with a high amperage charger. Those big chargers you see in gas stations are for fast charging a relatively healthy battery that was run down by an idiot. The correct way to resuscitate a dead battery is with a charger that will give short pulses of low amps. That way it has a chance to de-sulfate the plates. Once that is accomplished it will change over to a more robust charge. Modern smart chargers will do that.
10,581
14,326
UPDATE: I am faced with a dead battery that took an entire quart of distilled water. I am amazed it even worked at all in this state. Seems to be taking a charge. Then I wondered if it needed the acid replaced and I did a quick search. Unbelievably Amazon, Advance, NAPA, etc still offer QUAL brand acid in a 6 quart container. It can only ship via hazardous material carrier so best to get some at a local store. I guess you need to ask for or order some as they don't keep it laying around in plain sight for good reason.
Ribbedroof
4,927
7,067
Wellston, OK
Bought battery acid at OReilly a couple years ago. Got another 18 mos out that battery.
10,581
14,326
I love stories like that! My best ever was a battery someone tossed in the parking lot where I worked. It was an old Sears Die Hard with a semi-transparent case. I could see that it was super low on fluid and probably replaced out of ignorance. I took it home, flushed it out, refilled with new acid, and got 5 years out of it. I am hoping this one will take a full charge but if not I'll do the acid thing.
