I'm swapping the engine in my Regal to a small block and I need a new fan shroud. I cant seem to find any for small blocks online, is there ones for other models of cars? will the old one work?
Owning a few g-bodies over the years, I had 2 v6 models both with a/c, both converted to v8s. Cut to the chase, they both came equipped with a narrower radiator as compared to the v8 ones. This in turn made the shroud narrower than the v8 ones. The v6 ones were also longer fore and aft to accommodate the shorter v6s.Basically any g body with a V8 would work. An A/C V6 might work but you need to go for a 26” “header”( where the tank is soldered to the core) . Not sure if an F body would fit well.
