Grandprixpaul said:
I tryed for a while today to get idle down to under 1000 and keep the timing at 14 not sure wat im missing but i know i need the timing set at 14 from the guy who built it . But everytime i get the timing set at idle to 14 i have a high idle wtf dont remember having this problem with my other cars ,
you can't treat it this way... you have to pretend it's a relationship. More timing advance will naturally increase idle rpm and smoothness. Why are you set on the 14? How do you know it won't like less? or more?
And, you can't just set one and expect the other to set itself. You have to set your timing where you want it, then reset the idle. And if it's not smooth at that point, then play with idle metering screws. If metering doesn't get it where you want, then you may need to try full manifold vacuum advance. Or, you may need smaller/larger primary jets.
... there's so many adjustments... when you tweek one, you need to reset all the others.
get yourself a vacuum gauge, and a timing gun with digital advance... Setting your idle timing advance won't show you how motor performs at other rpms.
