Sbc swap in 78 cutlass
Yes
Unless you are going to source a 350 trans I would go with the 700r4 since it would be only a little more work than swapping in a 400 plus the low first gear will help you get moving if you have your stock rear gear and you also have the benefit of not revving the engine really high if you go on the freeway.
And most aftermarket 168 tooth flexplates are dual bolt pattern and can be purchased for $30 from Summit Racing for non SFI versions
I think I will go with the 700r4 seams like less work cuz I don't have the money to change a lot on this car this year
This is my cutlass hope the picture shows
