700r4 will require an aftermarket crossmember (or modifications to the original) and a frame extension for the driver's side on your car (and all G body prior to 1984)
I would like to keep it more simple as possible and the trans my uncle has is a th400 not the 350 i miss understood700r4 will require an aftermarket crossmember (or modifications to the original) and a frame extension for the driver's side on your car (and all G body prior to 1984)
Ok anything else that you can think ofTH400 will require same mods as 700R4
I plan on doing this swap for now but come this winter I'm making plans for a different swap it's just a cruiser for now but my next swap I wanna have a car with power something that I can drive on good days and some nights to playIf it's a cruiser not a hotrod, in the long run, the th350 will be way easier to use, and lighter too.
TH400 may require a different flexplate depending on torque convertor used. Starter nose will almost always need to be changed. These are because the TH400 usually uses the large flexplate (168 tooth), and most others use a smaller one (153 tooth). It's been a long time since I was swapping this stuff around frequently, so I'm sure some of the other guys can pick up my slack.
As I recall, some aftermarket flexplates have multiple TC bolt patterns on them.
Ok thank you for ur information I really appreciate itThe TH400 will require a different slip yoke, and you will need to verify proper driveshaft length/slipyoke engagement into the trans
