SBC VALVE SEALS????'s
Daily driver, weekend cruiser, street/strip or mostly strip?
What header and carb?
Do you have a means of measuring the installed height? If yes, then most everything should be reuseable (I believe). This is not a quick process to do it right - right meaning measuring and shimming as needed. Of course you can just chuck them on there and call it good. If you don't expect to be spinning this much over 5500-6000 rpm's, then I'm sure it will work. It's a matter of your concern for making sure it is precise or 'kinda close' lol.
I'm confident that if you were to contact Promaxx and tell them the spring your looking to install, then they could confirm if you need different locators, shims, retainers, etc. I would do that if I were in your shoes.
Good luck - Jim
Reactions: fleming442
Those are the same springs I use in my 306s flat tappet cam. Spring dia. is different which might require different retainers.
Skip to the beginning of the images gallery
Magnum 260/260 Solid Flat Cam for Chevrolet Small Block​
SOLID: Street / strip. 3500+ stall, 10.5:1 compression. Low gears, headers and intake. Racy idle. This is a cam only.
SKU
12-225-4
$169.95
Starting at $16/mo with Affirm. Learn more
Qty
Add to Cart
Wish List Compare
Email
Details
Specifications
Product Attachments
Recommended Components
Component Part Number
Break-In Lube:159
CL-Kit Upgrade:CL12-225-4
K-Kit Upgrade:K12-225-4
Lifter Kit:800-16 / 813-16
Rocker Arms:1412-16
RP Rocker Push Rod Kit:RPM1412-16
SK-Kit Upgrade:SK12-225-4
Steel Retainers:730-16 / 740-16
Timing Set:2100 / 3100
Valve Locks:611-16 / 613-16
Valve Seals:503-16
Valve Springs:986-16 / 987-16
3/4 of the cams in the Comp catalog recommend using those springs. They are about the equivalent of the infamous 'Z28 springs' that came to fame on the DZ302.
Correct me please if I'm mistaken.
