That's not going against the grain, that's going with the herd.
You can't do anything with a sbc that hasn't been done 10,000 times. Kickass would be 600hp big block chevy or Ford or mopar etc. Or a new generation something with turbos.
I'll be vote # 5,847 for keeping an olds in an olds!ascates said:New here with a cutlass
What do I need to know about swapping out the 307 for something more powerful? Do I need to keep it olds or switch to a chevy block? The prior owner of my cutlass replaced the original trans with a 350.
IMHO, a 200-4R (overdrive transmission)...there has been a lot of discussions on here about which is better, a 200-4R, or the 700R, although depending on your power, you may want to upgrade either with stronger internals. It (200-4R) comes in a dual-bolt pattern (IIRC)..ascates said:Hypothetically speaking...If I was to swap for a 350 sbc, is there anything else I would have to change besides the motor mounts and transmission? I've heard that some olds trans have bolt patterns for both olds and chevy. Is a th350 my best choice for a transmission? What if I want overdrive?
Just keep it hypothetical!ascates said:Hypothetically speaking...If I was to swap for a 350 sbc, is there anything else I would have to change besides the motor mounts and transmission? I've heard that some olds trans have bolt patterns for both olds and chevy. Is a th350 my best choice for a transmission? What if I want overdrive?
