87 El Camino
305 Automatic Column Shift
I'm having an issue where I have to pull the shift lever up (when already in Park) in order to get the ignition lock cylinder to turn all the way back where I can remove the key from the ignition. Is there something that's out of adjustment or broken? I've searched but I'm not seeing a similar issue.
