Oldmansmonte seen you post but didn't quite understand what should be done. Just to put more light on the transmission being wired to an ignition source.
Here is what i did. Just wire up the purple wire (4th gear pressure switch wire (lockup solenoid )to your ignition (hot) an converter will lockup automatically when 4th gear(OD) pressure is create. with that being said I'm wondering if its not unlocking/downshift once I step on the gas or break if that makes sense.![BLAM :blam: :blam:](https://cdn-0.gbodyforum.com/oldsmilies/BLAM.gif)
