CUTLASS Smaller brake booster to clear VC
DonF
Nov 1, 2015
69
Ft. Myers/ Lehigh Fl.
I know someone has done it. I have the oem 85 9" booster now, my BBOlds valve covers barely squeeze in now. I'm switching to the cast aluminum Olds covers and want a little more room. What size, brand, part #.... whatever info have you gone with?
Sweet_Johnny
Has A Face For Radio
668
1,217
Wichita, Kansas
Perhaps manual brakes? Then there's no booster in the way at all. I think most swap from a 12" single diaphragm to a 9" double for an upgrade. You may need to change the master cylinder if you go smaller than the 9" jobber you've already got. I guess you can try the aftermarket offerings, but I know nothing about them.
UC645
1,083
3,072
Kittanning, Pa
There is an alternative:
But a hydroboost system is difficult to piece together, on top of needing a different steering pump reservoir, and it’ll require a large bore MC.
Tbh, I’d go with a well calibrated manual brake setup.
64nailhead
Goat Herder
Dec 1, 2014
5,710
12,219
Upstate NY
If you have the double diaphragm booster, then that is small as it gets with a factory booster.
Be careful of buying low budget off shore 7" boosters. I have not had good luck with those little dinky ones on a heavy vehicle.
565bbchevy
9,614
12,683
Michigan
I have a BBC with the 9" dual and have never had a problem getting my tall valve covers off with a stud girdle so I am surprised the BBO would have issues.
Bengler455
19
11
It is the angle of the oldsmobile blocks that makes it an issue
Sweet_Johnny
668
1,217
Wichita, Kansas
I gave up on this post quite some time ago. I picked up a booster but have yet to install it yet due to timing and space.
Right on. Out of curiosity, what booster did you select?
