while you have the hole open sway some lube in there to settle for a couple months. You may just get lucky and have one of that bolt come out intact. My car had that bolt when I bought it but somewhere along the line it just disappeared .......
Nah. That bolt just spins. It's gonna have to either fall out or be cut out.while you have the hole open sway some lube in there to settle for a couple months. You may just get lucky and have one of that bolt come out intact. My car had that bolt when I bought it but somewhere along the line it just disappeared .......
Yeah, the cage is free spinning with the bolt. And I hear ya on that banging sound. It makes the car sound like it's... well like the body and frame are tying to part ways. I'll probably go the method of chopping up my formerly pristine trunk floor in those spots and welding in fresh metal. What a time to learn how to weld.Point is the bolt spins but it is still intact. That means there is a parallegram plate of steel that the bolt threads into which is still in the body of the car ( aka body mount pocket ). If the bolt is intact and not fallen out then the cage is busted or rotten letting it spin. If you lube it down you have the chance of drilling a hole or cutting a flap up on your trunk floor along the line of the hole you have now. Thus by wedging that steel plate with a pry bar you have a slight chance to un-thread the bolt instead of breaking it. Then you can go the hockey puck route ( because roadkill ) and replace that bushing instead of letting it flop around like a rotten banana.
IIRC on my car of the 4 rear mounts in total I had 2 missing, 1 broke and the last came out whilst stripping the thread out of the block I mentioned. I cut 4x round holes in the trunk floor, to gain access to those plates and tried to reuse them by running the tap thru them but the cages were still shot so I re-engineered it. I used SAE bolts and nyloc Nuts with new body mounts and the big flat washers that came in the kit to sew it all back together because the banging of the frame on the body over railroad tracks was making me mental. Takes 2 people though. One under the car and a monkey in the trunk with the torque wrench. Put mine in threads down as there is more room under the car if your bolts are a little longer.
