speakers
87MonteSS
304
Winnipeg, Canada
Should be 4 x 10 in the rear deck and 3.5" round in the dash, if the car was ordered with that option.
Are there two speaker grills in the dash? If so, the 3.5" go there, if not, you're out of luck up front without modifying the door panels to get a set of 4" in there. Anything bigger than 4" in the doors is going to require spacer plates to build out the panels. You might get lucky with 6" in the doors as long as the car doesn't have power windows.
As for the 4 x 10 rears, that's the factory size, held in by a set of spring clips. You can get 6 x 9 adapters though.
