Speedway Front Tubular Control Arm Kit
scarborough
278
52
Now that is for the uppers only, at one time there was a kit available that had the uppers and lowers together.
And I guess the kit isn't available any longer.
I considering purchasing those same arms for my 87 cutlass. the sale person i talk to at speedway said the lowers are out of stock until sept. the other problem I've run into is the alignment shops I contacted said they could not do and alignment.
also I'm wondering if the stock control arm spec can be use to align the tubular arms.
the impression I got from them is that they didn't know either. it may a good ideal to check your local alignment shop in your area to see if they can.
so now I'm thinking of just going back with the stock arms since its just a daily. there's not a lot of mechanic around that can work on these old cars.
57 Handyman
284
310
When I went to get my Elky aligned, I made sure the alignment specialist was an old school guy who cut his teeth on older vehicles. The reason you have problems like you experienced is nowadays most alignment shops only rely on computerized alignment racks. So, although I had alignment specifications from SC&C, the alignment mechanic.was able to use his experience and knowledge to dial-in the front suspension on my car. I don't have the specs handy at the moment but will be happy to post them later.
I suggest you ask around and find a place with older mechanics.
uneek1976
653
129
Sugar Grove IL/ Chicago
I have a guy who has a shop out in Michigan that actually just got a new alignment machine. He's a gbody and car enthusiasts, so I can leave that part for him
64nailhead
Goat Herder
5,396
11,363
Upstate NY
Wow, that’s the cheapest I’ve ever seen these. I wonder how the compare to others?
Wraith
1,561
4,558
DFW, TX
uneek1976
653
129
g3chevy
120
264
Spring, Texas
Just purchased these Speedway Motors control arms about a month ago. 3 days later I got the recall notice so I shipped them back. Here is what they had to fix due to several failures they were aware of.
