Just thinking about it check the contact brush the at the bottom of where the coil sits. If it's worn out it won't make contact with the rotor, not passing the voltage to the spark plug wire.
While you're in there, grab a section of 18ga. wire, put a ring terminal on it, ground it to the same screw, that the coil's ring, feed it through the center of the plug, and ground it to the firewall. Unless, you can come up with one of these in Tahiti
Nevermind, in the 2nd pic, I can see you already have it. Just make sure you have a ground on the center wire of the 3 pin plug. The ground for the coil isn't entirely necessary, but it is a good idea to have it.ok so I just tested my coil like in the video and the values seems to be ok : I have 0.5 ohms between white and yellow wire wheras the guys has 0.4 ohms.
and then I have 8850 ohms between the center of the coil and the ground... so it seems to be ok !
here is a photo of the little spring there is under the coil, but it seems to be in good shape !
sorry I didn't understand what you say, I take a wire, ground it with the same screw where theres is the ring on the coil yes ok ! but then where do I ground it? what is the firewall ?
do you think that the ground of my coil is bad ?
what else can I check next ? I have to pull out the rotor ?
