Yes it is louder, more powerful, with engine not running. I do not believe it is voltage drop, I have a volt meter and it stays at 14.
Stereo is a new Pioneer kit, single din head unit with bluetooth and no CD, and came with 4 - 6” speakers. I know they are lower quality but i have installed probably 10 of these with nothing but success every time.
Pioneer harness has two power wires, one constant and one for accessory. I am using factory power (key-on) and factory ground. I am thinking now maybe i should run my own ground. I ended up running the factory key-on wire to the pioneer harness constant and accessory spliced together to run the above suggested Pipemans noise filter unit, which just has a power in, power out, and ground (which i ran to body). Noise filter unit is installed between the power-in and the head unit, per instructions. I think it may have helped some but not all. I am using the factory fuse location on the fuse block for radio power.
