Stock 305 - L69 - What Timing Are You Running
ed1948
1,286
1,613
Quinte West, Ontario
I tried advancing the static timing to 11* with 91 grade gas, and still get detonation(pinging) under heavy load. I thought the CPU would pull back the timing. On your computer controlled carb what timing works for you?
A lot depends on how the centrifugal advance and the vacuum are set up. Here is a good read I found a while back
TIMING AND VACUUM ADVANCE 101
The most important concept to understand is that lean mixtures, such as at idle and steady highway cruise, take longer to burn than rich mixtures; idle in particular, as idle mixture is affected by exhaust gas dilution. This requires that lean mixtures have "the fire lit" earlier in the compression cycle (spark timing advanced), allowing more burn time so that peak cylinder pressure is reached just after TDC for peak efficiency and reduced exhaust gas temperature (wasted combustion energy). Rich mixtures, on the other hand, burn faster than lean mixtures, so they need to have "the fire lit" later in the compression cycle (spark timing retarded slightly) so maximum cylinder pressure is still achieved at the same point after TDC as with the lean mixture, for maximum efficiency.
The centrifugal advance system in a distributor advances spark timing purely as a function of engine rpm (irrespective of engine load or operating conditions), with the amount of advance and the rate at which it comes in determined by the weights and springs on top of the autocam mechanism. The amount of advance added by the distributor, combined with initial static timing, is "total timing" (i.e., the 34-36 degrees at high rpm that most SBC's like). Vacuum advance has absolutely nothing to do with total timing or performance, as when the throttle is opened, manifold vacuum drops essentially to zero, and the vacuum advance drops out entirely; it has no part in the "total timing" equation.
At idle, the engine needs additional spark advance in order to fire that lean, diluted mixture earlier in order to develop maximum cylinder pressure at the proper point, so the vacuum advance can (connected to manifold vacuum, not "ported" vacuum - more on that aberration later) is activated by the high manifold vacuum, and adds about 15 degrees of spark advance, on top of the initial static timing setting (i.e., if your static timing is at 10 degrees, at idle it's actually around 25 degrees with the vacuum advance connected). The same thing occurs at steady-state highway cruise; the mixture is lean, takes longer to burn, the load on the engine is low, the manifold vacuum is high, so the vacuum advance is again deployed, and if you had a timing light set up so you could see the balancer as you were going down the highway, you'd see about 50 degrees advance (10 degrees initial, 20-25 degrees from the centrifugal advance, and 15 degrees from the vacuum advance) at steady-state cruise (it only takes about 40 horsepower to cruise at 50mph).
When you accelerate, the mixture is instantly enriched (by the accelerator pump, power valve, etc.), burns faster, doesn't need the additional spark advance, and when the throttle plates open, manifold vacuum drops, and the vacuum advance can returns to zero, retarding the spark timing back to what is provided by the initial static timing plus the centrifugal advance provided by the distributor at that engine rpm; the vacuum advance doesn't come back into play until you back off the gas and manifold vacuum increases again as you return to steady-state cruise, when the mixture again becomes lean.
The key difference is that centrifugal advance (in the distributor autocam via weights and springs) is purely rpm-sensitive; nothing changes it except changes in rpm. Vacuum advance, on the other hand, responds to engine load and rapidly-changing operating conditions, providing the correct degree of spark advance at any point in time based on engine load, to deal with both lean and rich mixture conditions. By today's terms, this was a relatively crude mechanical system, but it did a good job of optimizing engine efficiency, throttle response, fuel economy, and idle cooling, with absolutely ZERO effect on wide-open throttle performance, as vacuum advance is inoperative under wide-open throttle conditions. In modern cars with computerized engine controllers, all those sensors and the controller change both mixture and spark timing 50 to 100 times per second, and we don't even HAVE a distributor any more - it's all electronic.
Now, to the widely-misunderstood manifold-vs.-ported vacuum aberration. After 30-40 years of controlling vacuum advance with full manifold vacuum, along came emissions requirements, years before catalytic converter technology had been developed, and all manner of crude band-aid systems were developed to try and reduce hydrocarbons and oxides of nitrogen in the exhaust stream. One of these band-aids was "ported spark", which moved the vacuum pickup orifice in the carburetor venturi from below the throttle plate (where it was exposed to full manifold vacuum at idle) to above the throttle plate, where it saw no manifold vacuum at all at idle. This meant the vacuum advance was inoperative at idle (retarding spark timing from its optimum value), and these applications also had VERY low initial static timing (usually 4 degrees or less, and some actually were set at 2 degrees AFTER TDC). This was done in order to increase exhaust gas temperature (due to "lighting the fire late") to improve the effectiveness of the "afterburning" of hydrocarbons by the air injected into the exhaust manifolds by the A.I.R. system; as a result, these engines ran like crap, and an enormous amount of wasted heat energy was transferred through the exhaust port walls into the coolant, causing them to run hot at idle - cylinder pressure fell off, engine temperatures went up, combustion efficiency went down the drain, and fuel economy went down with it.
If you look at the centrifugal advance calibrations for these "ported spark, late-timed" engines, you'll see that instead of having 20 degrees of advance, they had up to 34 degrees of advance in the distributor, in order to get back to the 34-36 degrees "total timing" at high rpm wide-open throttle to get some of the performance back. The vacuum advance still worked at steady-state highway cruise (lean mixture = low emissions), but it was inoperative at idle, which caused all manner of problems - "ported vacuum" was strictly an early, pre-converter crude emissions strategy, and nothing more.
What about the Harry high-school non-vacuum advance polished billet "whizbang" distributors you see in the Summit and Jeg's catalogs? They're JUNK on a street-driven car, but some people keep buying them because they're "race car" parts, so they must be "good for my car" - they're NOT. "Race cars" run at wide-open throttle, rich mixture, full load, and high rpm all the time, so they don't need a system (vacuum advance) to deal with the full range of driving conditions encountered in street operation. Anyone driving a street-driven car without manifold-connected vacuum advance is sacrificing idle cooling, throttle response, engine efficiency, and fuel economy, probably because they don't understand what vacuum advance is, how it works, and what it's for - there are lots of long-time experienced "mechanics" who don't understand the principles and operation of vacuum advance either, so they're not alone.
Vacuum advance calibrations are different between stock engines and modified engines, especially if you have a lot of cam and have relatively low manifold vacuum at idle. Most stock vacuum advance cans aren’t fully-deployed until they see about 15” Hg. Manifold vacuum, so those cans don’t work very well on a modified engine; with less than 15” Hg. at a rough idle, the stock can will “dither” in and out in response to the rapidly-changing manifold vacuum, constantly varying the amount of vacuum advance, which creates an unstable idle. Modified engines with more cam that generate less than 15” Hg. of vacuum at idle need a vacuum advance can that’s fully-deployed at least 1”, preferably 2” of vacuum less than idle vacuum level so idle advance is solid and stable; the Echlin #VC-1810 advance can (about $10 at NAPA) provides the same amount of advance as the stock can (15 degrees), but is fully-deployed at only 8” of vacuum, so there is no variation in idle timing even with a stout cam.
For peak engine performance, driveability, idle cooling and efficiency in a street-driven car, you need vacuum advance, connected to full manifold vacuum. Absolutely. Positively. Don't ask Summit or Jeg's about it – they don’t understand it, they're on commission, and they want to sell "race car" parts.
Thanks lilbowtie...that's a good read, educational.
Mine is a computer controlled distrib and I guess temperature and manifold vacuum (MAP sensor) are deciding factors on variable timing.
a carbon build up on the piston and in the combustion chamber increase the temperature of the combustion chamber which can cause pre-detonation
Reactions: Texas82GP
I have this bookmarked from when I ran the CCC on my car. Its for the 307 but the components are the same.
Forgive my memory but I recall that if its pinging then if "should" trigger the knock sensor and pull back the electronic timing advance in the distributor. So at this point I would pull back the base timing a hair as it could be either too advanced at the base or the knock sensor is faulty ( which you would think would throw a code). No idea how to check the condition of a knock sensor but it works in hand with the ECE ( I think that's what it was called )
FWIW the CCC distributor only controls the advance curve ( vs a non ccc distributor which would have a mechanical vacuum advance ). Your base timing is set manually so the computer can only compensate with whatever timing is in the distributor to achieve 14.7 with no knock. So keep pulling timing out until you find the "happy" spot. There could be some slop in the timing chain as well. I don't suppose when you changed the water pump you rocked the crankshaft pully back and forth to check for obvious play ? 3rd gen & Montecarloss are great resources for the CCC system. Most everyone else ( like me ) has otherwise removed the CCC over the years
http://performanceolds307.tripod.com/id1.html
You have mentioned that you or your friend thought the car was down on power, and now you indicate you are hearing pinging. Check a few things:
1. Make sure the EGR diaphragm is intact by testing it with a Mighty Vac or equivalent.
2. Make sure the old original pancake catalytic converter isn't plugged.
My buddy in high school had an 85 Delta 88 (CCC 307 but essentially the same engine control system). The car had both problems mentioned above and when corrected the difference was amazing.
https://www.google.com/url?sa=t&sou...CB4wAA&usg=AFQjCNGlshicWB3TyRGoyI7g-ClnpB5FMA
Ed1948,
I'm guessing you have already did this but.... when you set the timing on this engine you did disconnect the 4 pin connector going to the distributor correct?
This will take the advance through the ECM out of the equation. My 88 Super Sport Monte Carlo engine tag calls for 6 deg BTC I run it at 8 . When I had the 350 in my 86 El Camino with the Monte Carlo SS ECM I ran it at 8 deg BTC with 89 octane pump gas. 10.5:1 Iron head engine with a Crane Comp u cam.
Hope this helps!
Bob S.
I would check for vacuum leaks as they can cause all sorts of strange problems. They usually do make engines run hot and cause havoc with CCC systems. I am running 10 btdc timing on 87 gas in my ccc car with no pinging.
low on power - I think can be attributed to the carb secondary spring being too tight
EGR - tested and functions ok
Cat - the large SS style, not pancake
I have yet to test drive 9* timing following the correct procedure
I have tested for vac leaks and found none so far, hoses are flexible and not cracked
I read- to test the knock sensor tap the block near it and watch the timing retard
  • Winner
More than just the vacuum hoses can leak vacuum. The intake manifold gaskets and carb mounting gaskets can also leak vacuum, as well as the brake booster.
