I took mine to a local exhaust shop and talked to the guy. He put a different muffler on it and split the exhaust there. The cat was previously removed. Sounds awesome. Nice throaty sound
But....but...don't you and your muffler guy know about the federal law?I took mine to a local exhaust shop and talked to the guy. He put a different muffler on it and split the exhaust there.
C'mon man.......don't you know some govt bureacrat (rather than yourself) gets to decide what exhaust you put on your car???Long tube ceramic coated headers, 2 1/2 pipe, two nice turbo mufflers dumped behind the rears wheels. Hagerty Insurance. I can do whatever I want and still drive it but mine is a toy. Thank you Arizona.
Do What? If you want more anything from a 307, you're going to have to add a turbo, a blower or a Procharger, any of which will hit you for $3000 just for the parts. Even then, you won't have half what you would with a 327 or 350 built right. Other than what I listed, if you try to do anything else to a 307, you're actually losing power and wasting money. Anything bigger than 2 inch pipes on a 305 or 307 kills the power because it needs restriction to help develop the little power that they make. Do some research. I tried it once on a 4WD Blazer just because the owner paid me to do it. It bogged it down so bad that he wanted 2 inch duals put back on.A test pipe will add sound, in place of the catalytic converter. If you need more, headers and true 2.25" or 2.5" dual exhaust will not only add sound but at least 30 hp/tq. Carefully remove the factory exhaust, including manifolds and store it away carefully. Nobody makes it and probably never will again. If that still isn't enough, a bigger cam adds sound but you can't go too big on a 5L with just over 8 to 1 compression. Good luck.
Maybe you should do a bit of research. VIN 9 Olds 307 used standard 2.25" exhuast. 2.5" wouldn't be a stretch if someone were to go that route.Anything bigger than 2 inch pipes on a 305 or 307 kills the power because it needs restriction to help develop the little power that they make. Do some research.
