Myself, I usually store a vehicle over the winter with a full tank of gas. Plus I add some Store-N-Start additive. That works fine if I am using the vehicle now and then, or it only sits over the winter. Nowadays I might go a full year without emptying a gas tank so the gas can be quite old.
My question is this: If our G-bodies are a sealed system, sealed gas cap, with no vent to atmosphere, can't they be left empty over the winter or longer? With no vent, there is no way for moisture to enter. It won't 'breath' like an open system thus keeping moisture out. The only opening would be the charcoal canister and that is far away from the gas tank. Would that keep moisture out? I guess if the vehicle gas tank was slowly run down during hot humid weather, there could be much moisture entering the tank . But what if the tank was siphoned down all at once during cold dry weather? What would go on with an empty tank? No fuel pump in the tank, so that is safe. The gas gauge sender? Submerged or dry? Does the gas cap 'breath'? How does air replace the gas? Canister, or gas cap? This driving me bonkers, please set me straight!
