Are you getting full TV pull at full throttle? My 88 2004R trans had 3000 rpm full throttle shifts. I modified the governor to get 4300 rpm shifts. I still can't be believe someone didn't put in a GN or Monte SS governor when the trans was built up. It is critical to this trans living that you get full TV pull at full throttle. And get new mounts, Dick Miller Racing sells the solid engine mounts. https://store.dickmillerracing.com/enginemounts.aspx Supercars Unlimited sells supposedly better motor mounts than the cheap anchor mounts everyone else sells. http://www.supercarsunlimited.com/403--Engine-Mount-d1986.aspx
