Why do you want to raise it?
because first off my frame isn't notched so the car won't even clear 16 inch wheels and I'm looking to put some 20 inches on it when im done with paint
Yea like mentioned above , your tire situation is dangerous ! Springs will probably be your first venture into raising ride height , and how much you raise it will determine the rest .
What engine is in it or will be in it? That will help narrow down the selection for front springs to get the height you looking for.
You could use stock A-Body w/Big Block or B-body w/Big Block coil springs to get some additional ride height. Shocks aren't meant lower or lift a vehicle, just soften the impact of roadway obstructions. New springs make a ton of difference on these cars; they really don't sit that low.
I am not sure why you would want to raise it but I would make sure your suspension and body mounts are in good shape first before attempting to do anything to change the ride height.
You don't need to lift it at all for some little 20" wheels. You need to buy wheels meant to fit your car specifically; that would also eliminate having to use spacers or notching the frame.
okay i see! Cause the two sets I have are universal but where for fords
F-body wheels have way too much backspacing for G-bodies. Forget about offset, that's for newer cars and imports, backspacing is what's important for these old cars. 4.5" backspacing is about the max for a wheel to fit a G-body in the rear without touching the frame.
Dodge and Ford wheels have a different bolt pattern altogether and should be avoided.
