Summit/G-Force/M&M Crossmember hitting floorpan?
moose
188
16
ICT, KS
Anyone here ever run into this problem with a cutlass? Have read/heard that some people with gbodies experience one side hitting the floor. It fits, just touches when it shouldn't. One blog stated that the problem didn't arise until new Energy body bushings were installed.
Also, is there any difference between the M&M crossmember and the current Summit/GForce?
M&M website states they reduced the weight to 18lbs from the early GForce 30lbs. How heavy are the current production Summit/GF?
dan2286
2,233
4
Cleveland, Ohio
I've heard that old squished body bushings will cause that issue. Not sure about your other question.
79loserbluebu
960
20
Illinois
If it touches beat the floorpan in a little bit. The crossmember is a beast it's pretty bulky.
Geed_up_442
280
16
A squished body bushing makes sense. I had that problem, nothing too serious though. When i was installing my (M&M) cross member it was butting up against the aluminum pan under the passenger seat. But it only took a pry bar to allow enough room to slide the crossmember back.
Peter
1,175
74
48
MA
get a tubular iceman crossmember. no fitment issues, tubular and cheaper
DoubleV
2,147
408
83
Medina Ohio
IMO, if something as simple as a crossmember can't be made to fit without bashing something on your car with a hammer, it's a crap part. The people making these things should take into account 95% of the cars these things will be installed in don't have brand new body mounts.
Over the years I tried a G-force on my car and it wasn't even close to fitting. Not going to bash a perfect floorboard to get that over weight POS to fit so I returned it. Tried a Jegster crossmember recently too and the same thing ( but better than the G-force ). Best solution IMO is to notch the factory crossmember. That way you know it actually fits and doesn't weigh a ton either.
19cutlass79
233
16
Yeah I am looking for a stocker for a 2004r now after trying a ice man, does not fit my wagon too well too much space between the pan and the member so trans sits low tilting the front of the motor up and causes the exhaust to sit lower also, but finding one in HI is hard.
Wade
84GP455
779
96
Methuen Ma.
I installed my G-force cross member back in 2002 with no problems, fit like a glove!Your car must be sagging or something. As far as being heavy or bulky, it actually reinforces the frame and stiffens it up and 30 lbs is not going to make your car go slower, the lack of horsepower will though. Weight only matters if you are racing it and are trying to shave of a half of a second off of your time. I like the thickness and strength of it, it made me feel like I got my money's worth and it supports my heavy TH400 very nicely.
